An oldie for you guys
Leon82
Leon82 Member Posts: 684
My aunts 1906 house has this guy in the basement.
  • njtommy
    njtommy Member Posts: 1,105
    Wow that's an oldie. that's got to be an oil hog.
  • BobC
    BobC Member Posts: 5,539
    Back when I first bought this house I had a DS-5 Delco steam boiler that was even larger and probably just as bad on oil.
    My cat used to sleep on it whenever she got into the cellar. One day I went down to check on the old girl, I went down the stairs and checked the sight glass and found it at the right level. As my eyes went up the boiler I found the neighborhood tom asleep on top of the boiler. He had forced one of the cracked cellar window panes out and made himself at home. It was a very cold night so I left him where he laid and built a flap into that window pane the next day.
    never saw a mouse in the cellar again as long as that old tom was around.
    Bob
    3PSI gauge
    aircooled81
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    edited February 2016
    Old gravity water boiler?still has old stack relay in flue...
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
  • Leon82
    I think so, I know its not steam.
  • Paul S_3
    It is a water boiler i see by the old strap-on aquastat on supply
    347-692-4777
    ASMHVACNYC.COM
  • Leon82
    This ones a higher picture
  • Paul S_3
    Looks like gravity water ....nice...very old used to be coal
    347-692-4777
    ASMHVACNYC.COM
  • JUGHNE
    JUGHNE Member Posts: 11,513
    2 large supplies and 2 large returns......open expansion tank perhaps in the attic, P & T gauge, aqua stat, stack control relay maybe from older oil burner??
  • Leon82
    I'm not sure the asbestos could be thick
  • deadmansghost
    deadmansghost Member Posts: 32
    The expansion tanks were in up stairs closets to prevent them from freezing and close to the bathroom for the water supply float valve. Over flow pipe was run into the bathroom drain above the trap on a hand basin
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Oldest Burnham I've ever seen.
    Steve Minnich
  • ChrisJ
    ChrisJ Member Posts: 17,070
    Good luck getting a new one to last even 1/4 of that.
  • John Mills_5
    John Mills_5 Member Posts: 952
    Why do people keep 100 year old boilers? Grandma had an antique in the 70s & 80s and paid an absolute fortune in oil. Every time I'd suggest modernizing she'd point out her age and say she might not be around to reap the savings. So she paid huge bills for a long time. She lived to 94 1/2!
  • ChrisJ
    Why do people do anything they do?
    You're asking a question not one person on this forum is qualified to answer.
    Hatterasguy
  • Leon82
    There's about 100 feet of asbestos covered pipe in the basement and they won't replace it until its removed.
    They are planing on abatement soon
  • Paul S_3
    Make sure installer is qualified on replacement of a gravity boiler or converting to forced circulation....high efficiency modulating condensing boiler would be perfect for this application....converting to gas too?
    347-692-4777
    ASMHVACNYC.COM
    njtommy
  • Leon82
    Its my aunts house, I'm not sure when they are planning it. they have a gas water heater so its an option.
