spirovent is leaking from the vent foaming glycol system
stmary
stmary Member Posts: 1
Can this be repaired or needs to be replaced?
    hot_rod Member Posts: 26,594
    Foam is hard for a vent tO deal with. Foaming glycol is often caused by dirty fluid conditions. You can buy anti foaming additives for glycol solutions. Or flush clean and start with fresh glycol, premixed with DI water
