boiler flue
Paul S_3
Member Posts: 1,291
Accordingly to NYC boiler code at what size and when does the flue of a atmospheric or power vented commercial boiler have to be welded?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Paul what kinda of boiler cast iron or steel? Cast iron minimum 22 gauge glue pipe and can be screwed together
Steel boilers welded. You can find that info on that info in the mechanical code and on the department of boiler/ boiler divisions website0 -
Cast iron. ....thanks ezzyASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Chapter 8 mechanical code NYC
http://www1.nyc.gov/assets/buildings/apps/pdf_viewer/viewer.html?file=2014CC_MC_Chapter8_Chimney_and_Vents.pdf§ion=conscode_2014
see attachedGennady Tsakh
Absolute Mechanical Co. Inc.0 -
Thank you gennadyASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
