chimney
nikos
nikos Member Posts: 16
can anyone advise me if im able to run the heatfab stainless steel pipe (FLUE) through the side of my house ,
and run it up to theroof? due to the fact that i dont want to break the interior of my house.
condensing boiler trinity tx151a
  • Bob Harper
    Bob Harper Member Posts: 1,176
    You must use the venting prescribed in the listed instructions and install it in accordance with the mfr.s instructions and the building code for clearances. You will need to check with mfr. to see if a special adapter is required to mate this vent pipe with this unit. Typically, this venting is not required to extend above the roof line but rather terminates right outside the sidewall.
