Weil McLain Ultra experts ?
KAD
KAD Member Posts: 2
New poster. I've had an Ultra 60 for maybe 8 years. It has trouble firing up. It lights , then I hear that motor boating sound , then it goes out. After so many tries I get an error . Can't remember code right now. I reset and it usually does the same thing. If I crack open the little sight glass while it is motor boating it will stay lit and then ramp up to high flame. Why would doing this let it light? I have cleaned it in the past and seemed to help. I've had this issue for years. Any ideas? Thanks
  • 4Johnpipe
    4Johnpipe Member Posts: 488
    May have condensate built up in the combustion and exhaust lines...
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
  • Aaron_in_Maine
    Aaron_in_Maine Member Posts: 315
    You need a full tear down and cleaning. The condensate is backing up like John said.
    kcopp
  • kcopp
    kcopp Member Posts: 4,630
    and a combustion test.....
  • KAD
    KAD Member Posts: 2
    Thanks for the comments. I did a full cleaning today. A lot of crude in the bottom and wet looking from the bottom halfway up. This is a propane burner. Thanks again.
  • Has that hopefully resolved the problem?--NBC
  • kcopp
    Did you use the service kit? Did you run a combustion test?
  • Aaron_in_Maine
    Make sure to get the cleaning kit it comes with gaskets. If I were you I would leave it to a pro. Just make sure that you let them know which unit you have when you call so they get the proper kit from Weil McLain.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Water in the flue collector? I know where this is headed......
    Aaron_in_Maine
