Too much pressure
JonDes1369
JonDes1369 Member Posts: 1
Looking for some help - I installed two new baseboard units yesterday. I connected them to an existing baseboard unit in another room. I turned the water back on - bleed the air out of the line - and everything seemed fine. I went down to the basement an hour later and water was coming from the release pressure value. I looked at the pressure gauge and it was in the red. I shut off the system and drained the water which reduced the pressure. I thought maybe air was trapped in the system (could be - I am not sure)
I thought maybe that I broke the expansion tank - it seems fine - the knock is different from the top to the bottom.
Any thoughts on what it might be?
    hot_rod Member Posts: 27,853
    Fill valves can fail to shut off completely after long periods of non use. Turn off the fill valve, lower the pressure in the system and observe.
  • nevele
    nevele Member Posts: 30
    Did you install the new heaters in series with the one in the other room. (complete the loop)
