Programmable TRVs?
Jeff W_2
Jeff W_2 Member Posts: 57
edited January 2016 in Thermostats and Controls
Does anyone know of a local manufacturer that makes and sells a programmable TRV? I know Danfoss makes one, but it isn't in the US market yet. I'm also looking for one with the remote wallmount operator- but programmable. Thanks in advance. Caleffi guys? This seems to be right up your alley- I can't believe these wouldn't sell like hotcakes.
  • hvacfreak2
    hvacfreak2 Member Posts: 500
    I have seen them on ebay but I have not heard any reliable feedback. They even have Bluetooth enabled models.
    hvacfreak
    Mechanical Enthusiast
    Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
    Easyio FG20 Controller
  • ChrisJ
    ChrisJ Member Posts: 17,412
    Do the programmable Danfoss heads work on the single pipe steam valve bodies?
  • hvacfreak2
    From what I have read on the detailed ads , yes ( RA-2000 ).
    hvacfreak
    hot_rod Member Posts: 27,505
    The Caleffi programmable is also a Euro model, metric units. I tried one on the radiator next to the bed. The gear train noise was a bit loud. Program it for your wake up time
  • Jeff W_2
    Hot Rod - so Caleffi makes one but not with a wall-mount operator?
  • vvzz
    vvzz Member Posts: 39
    Here's a manual for Danfoss programmable head. It looks like it comes with adapters for different valve bodies: http://heating.danfoss.com/pcmpdf/living-eco_viidb202.pdf
    Not positive what the of body is steam one.
  • Boon
    Boon Member Posts: 261
    Jeff, What did you end up using?
    DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.
