Mini Heat system options
lou8486
lou8486 Member Posts: 1
I will need 33,480 BTU/hour or 9,812 watt. This unit will heat a small addition to the main house independently. Resources for fuel are oil, electric,and propane. The smoke pipe can handle 200,000btu but the main burner system and water heater use all of that. So, It will need separate exhaust or no exhaust.
We are considering a propane mini condenser boiler with forced exhaust. Or a Tankless electric hot water heater.
What is most economical option? Is There another way?
House is in Ny.
new addition has baseboard installed.
  • kcopp
    kcopp Member Posts: 4,695
    edited January 2016
    I have installed this unit on an install. IBC HC. 13.5-51k
    http://ibcboiler.com/ibc-products/hc-series/
    I really like this boiler.
    Are you sure that the existing boiler wont handle the extra load?
    Most boilers are over sized.
    KC_Jones
  • wogpa67
    wogpa67 Member Posts: 238
    What type of system do you currently have?
  • Gordy
    Gordy Member Posts: 9,546
    You will have to compare fuel costs in your area. Oil, and propane can be volatile, and electric can be pricey, but not as volatile.
    SWEIRich_49
