Webstone was leaking, now it's not
GW
Member Posts: 5,211
in Geothermal
We installed a couple of Webstone 58654 for a geothermal system, one was leaking on the mechanical connection (very minor, a drip every few minutes maybe). I ordered a replacement and was about to set up a time to go replace it. System was pressure was low at the initial filling, about 30 psi. I want to jack it to 70-80.
Now, it stopped leaking. Is it possible these things are prone to leak in the beginning?
maybe one of my more stupid questions, but hey it's Monday
Thanks, Gary
Thanks, Gary
mechanical connection? Is it a press version?Bob "hot rod" Rohr
Living the hydronic dream0 -
I'm going to assume he means the valve stem or a joint in the valve housing it self.
If it was mine, I'd replace it. If it leaked once, it'll leak again most likely when you least want it to.
Thanks for the comments. I've never unscrewed one of these, ,never had a leak. I did have to torch it twice, I needed more room to get the fusion iron (I realize you can't picture this) in place, you know the iron takes a few extra inches
I may as well replace it while the flush cart is still in the basement!1 -
I know what you are saying on the fusion iron. Incredibly easy to paint oneself in a corner.
I frequently find myself in your shoes, whatever the situation may be. While it is tempting to leave something slide that is in the proverbial "gray area", over the course of time it is always the best choice to get things 100% and avoid that expensive call back, which will come at the most inopportune time with a disgruntled customer to boot.0 -
- 129 Chimneys & Flues
- 122 Geothermal
