Venting for wall hung modular/boiler in nyc
Heeltee
Member Posts: 20
I would like to install a wall hung modular or wall hung boiler in my house in nyc. does any one know the code for venting in nyc ? Thanks
It's unlikely to happen unless you're in a free-standing home in the outer boroughs. You won't have the clearance from building penetrations to your vent termination unless you go to the roof, independent from any other flues. In other words, the only way high efficiency, direct vent appliances pass Code inspections in NYC is when they vent to the roof in a dedicated, fire-rated enclosure and the venting material is polypropylene or AL29-4C (UL Listing #1738).
The City HATES, and in most cases forbids, venting over anything that can be considered a walkway or sundeck, close proximities to lot lines, plumes of exhaust visible to neighboring residents, etc. And they want drawings filed that are stamped by a Registered Architect or Professional Engineer.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
Yes I am in queens county and I have plenty of room between neighbors .thanks for the advice..0
how about sch 80 cpvc ?0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 891 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
