Triangle Tube Excellence Problem
Paul Pollets
Member Posts: 3,661
I installed a TT Excellence 110 about 5 years ago that uses 12 wall panel radiators and of course, provides DHW. The CW feed is manual and the boiler drops to zero pressure with 4 hrs. of filling to 15PSI. There are no obvious leaks on the system or underneath the boiler or "near-boiler" piping. The system starts up immediately after re-filling. The boiler relief valve was replaced yesterday. Anybody have some ideas?
Pinhole in a tube? Goes right out the condensate drain unnoticed. Had a Solo 110 with that once.To learn more about this professional, click here to visit their ad in Find A Contractor.3
The expansion tank is fully charged and not leaking.
Robert, How would one tell if there's a pinhole in the firetube HX?0 -
Isolate, drain boiler and air test for an hour + or -. You may want to remove and plug relief valve hole, then test to 50psiTom
Montpelier Vt0 -
I went back last night and there was no condensate at high temp. Looked further and there was a small leak at union nut(s) on thermostatic anti-scald valve and a tiny pinhole leak at solder joint under union nuts.0
Good catch.
For the few (older) systems that actually require an auto feeder, we still try to avoid leaving them on 100% of the time. The laying of even fractionally educated human eyes on a system every month or so has some real value.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 891 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
