Can steam pressure ever be too low??
Hi All.
I made some tweaks to my steam boiler this fall. One change was replacing the "hissing" main vents. Replaced all my Hoffman main vents (74's and 75's) with Gorton #2's (3 main vents total). Also gave them all AT LEAST 8" vertical clearance from the main (previously were threaded straight into the mains). The overall pressure in the system dropped considerably- so low I couldn't detect it. I added a compound gauge and a 0-3psi gauge (kept the code-required 0-30). The pressure never builds up over 4 inches H 2 0 (~0.145psi) when firing; stabilizes at ~-0.07psi (vacuum) when idle (not firing).
Is there any downside to pressure this low?
I've read all of Dan's books. I cant even get the pressure up to 0.5 psi! Did I go overkill? Will I damage anything?
The results have been pretty amazing- the house heats much quicker and evenly... and my fuel $$ dropped nearly 300%... all in line with what Dan says in his books.
All replies welcomed.
Thank you all.
-Billy
Weil-McLain EG-75
2-Pipe Steam
Gravity-Return
  • KC_Jones
    KC_Jones Member Posts: 5,907
    Ask @ChrisJ You have what you want low pressure. I think Chris gets way lower than that.
    2014 Weil Mclain EG-40
    ChrisJ
  • ChrisJ
    ChrisJ Member Posts: 17,068
    Billy,
    Here's a video showing my pressure at the boiler when it's 10F outside. Though since adding a snubber the overall pressure reading stays slightly lower. My system shuts down for 10 minutes if I hit 1" WC and it never does, as of yet anyway.
    https://youtu.be/hH36luC9GKU
    StuckWithSteam
  • ChrisJ
    To answer your specific question, can it ever be too low?
    Yes, if you have problems with radiators not heating no matter what you do with venting, otherwise, no.
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,529
    Exactly. If all your radiators are heating, you're running a nicely balanced system. You're running right where you want to be, no overkill at all. Nice.
    newenglandsteamworks.com
  • Billy_13
    Billy_13 Member Posts: 15
    Guys,
    Thank you all for replying. I can't tell you how good it feels to have that peace-of-mind. Got a couple below zero nights this week in the Steel City. Excited to see how this holds up- first winter in this house.
    Thanks Everyone!
    -Billy
