thermostat location
papa12603
Member Posts: 13
I have a 13 units building. I have an hb smith gas steam boiler I am still to determent where to locate the thermostat for better efficiency. I have large and small size apts. Building is 3 floors high.
The best location would be on an uninsulated outside wall.
Just kidding !!!
I would think that the best means of control would be a Heat Timer or similar control / strategy but I have not been involved with a similar application for a long time. But choosing 1 single location for a thermostat you would do just as well rolling dice or picking a location out of a hat. Furthest radiator , center of the building , no single choice is really right to represent the entire building. A better way might be to average an occupied unit on each floor. These sensors could be brought into a controller that would average 3 analog inputs and fire the boiler until a set point is reached along with some specifics for steam systems ( pid with some event limits ).hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
I wouldn't use a single thermostat. I've installed these with good success: http://www.rdcontrolsystems.com/steam-200-series.php0
What is the cost of the rd control system? I cant find it in the site of the link! Thanks abracadabra and hvacfreak!
OK I got it sorry0
- 114 Geothermal
