New steam radiator too high for valve
Thank you!
First the valve and spud are a matched set, you can't connect on rad to another rads valve and have them seal. You will either need the valve from the "new" rad or the spud from the old rad or a entirely new valve and spud. That being said sometimes you can just pull up a bit on the valve and there is enough "slack" to make the connection. If that doesn't work you can remove the valve and use and extension piece on the pipe to get the valve up higher. If that doesn't work you can use a couple of 45° elbows on the radiator outlet to offset slightly down then install the spud into them and make the connection.2
Is there no way to fix the leak?Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Thank you @KC_Jones !! I am a little confused by the option with the 45 degree elbows - how does the spud fit in with the elbows? I might be thinking of a different configuration...KC_Jones said:
Short nipple into the radiator, 45° elbow, close nipple, another elbow then the spud. The 2 45's allow for a slight offset in the vertical direction. The only "problem" would be the need to move the rad closer or further from the wall. Others may have other ideas.0
1/2" longerAbracadabra said:Other options, trim the legs of the radiator or install a extension on the riser and raise the entire raidiator up. The other and probably most difficult would be to remove the nipple coming up from the floor and replace with a nipple about 1/2" shorter
@Abracadabra what is the nipple coming up from the floor?Abracadabra said:Other options, trim the legs of the radiator or install a extension on the riser and raise the entire raidiator up. The other and probably most difficult would be to remove the nipple coming up from the floor and replace with a nipple about 1/2" shorter
Is something like this your extension option if it was straight: http://www.supplyhouse.com/Jinan-J-BLXP-10-1-Black-Extension-Piece
Thank you!0 -
Yes that's the extender. It might not get it perfect, but if it gets you equal or higher you are golden. If it's higher you can shim the feet with a few quaters or as I do sliced of hardwood dowel.0
I don't understand.. The nipple is the piece that comes up thru the floor... the pipe.. Is that what you're asking?steamheatnewb said:
Thank you!0 -
This is resolved
used an extender and it all fit together nicely. Thank you everyone for the help!
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
