Boiler continues to run when thermostats are satisfied
tkmoore1955
Member Posts: 3
I have three zone boiler and the boiler comes on when thermostats are satisfied what's wrong?
Does the boiler heat your domestic hot water?
3PSI gauge0 -
No I have a hot water heater0
How old is this system, if its old enough it may be a 'hot' boiler. Still see a few of them around.
pics would be nice.0 -
If it's new enough it may have wwsd. The wall folks like pictures, because most of this stuff is kinda technical.0
You may just have a stuck end switch. Smack the zone valves.0
If it's an older boiler it may be the aqua stat relay or boiler control. Some have a preset low limit some can be adjusted.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
Agreed...whether you're using it or not, the boiler may have a domestic coil and triple aquastat.0
Are all three zones heating, or just one? do you have zone valves or circulators? I recently had a job where this happened. Drove me crazy. turns out the 3rd floor thermostat wire ran into an attic where squirrels were chewing on the wires. Wires touch, your heat doesn't turn off.
Robert O'Connor/NJ0
