Old Wirsbo Manifold Warranty
Dobber
Dobber Member Posts: 91
Does anyone remember what the warranty was for the old brass Wirsbo radiant manifolds?
Dobber
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    edited November 2015
    I'm quite certain it was 1 year.
    Steve Minnich
  • rick in Alaska
    rick in Alaska Member Posts: 1,510
    Now the stems are starting to leak and you can't get them no more. Have to replace the entire manifold. I wish they would leave things alone.
    Rick
  • Are these valve stems which could be repacked?--NBC
  • Rich_49
    Rich_49 Member Posts: 2,785
    Which manifolds are they , TruFlow Classic , TruFlow Jr or something earlier ?
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
  • rick in Alaska
    I believe they are the classics. The ones that are rough metal and mostly round.Would take a very tiny o-ring to repack them.
    I saw one on e-bay for $100. Capitalism at its best.
    Rick
    hot_rod Member Posts: 26,471
    Maybe look for an o-_ring replacements via local or online sources.
    Most of the hydraulic hose and cylinder shops, that do construction equipment repairs, tractors, backhoes, etc, have a wide selection of standard and metric size rings in a kit. Take a ring along or use a caliper to get the diameter of the stem.
    SWEI
  • rick in Alaska
    Pretty tiny o-ring, but hydraulic shop might have them. I guess I could get some for the Taco 5000 mixing valves as well. They all seem to leak after awhile, especially if you try to adjust them.
    Rick
  • There is a lot to be said for the classic valve design with a nut compressing graphite or Teflon string-Almost always repairable!--NBC
    Rick
    If you think they are leaking or failing prematurely, check the fluid quality.
    Sometimes the "stuff" in the system from day one compromises seals.
    Hardness, ph, chlorides grit, etc,etc. Chlorides are the big concern now, especially with multimetal systems. Check the ingredients on some solder fluxes! A good hydronic cleaner, even in new systems, is well worth the money.
    SWEI
  • rick in Alaska
    Good point. Something to look at.
    Need to get a test kit for the various things and start testing each job.
    Rick
    ph also. There are some dual gauges, I like separate.
    No need to spend a lot of $$. the simple, inexpensive pocket meters are fine.
