Radiator Help
Louise8589
Member Posts: 1
in Gas Heating
Hoping someone can help. I've had the problem last year where one of my radiators lost most of the heat after turning the thermostat down to zero, problem was resolved unfortunately I can't remember how. I now have the same problem again after making the mistake of turning the thermostat downn and then turning it back up the lounge radiator won't heat back up , the pipes on the radiator are hot, bottom of radiator nearly cold and top Luke warm. I've tried to bled it and checked the pressure. Anyone got any other suggestions?
- 128 Chimneys & Flues
