Propane tank over filled
GW
Member Posts: 5,188
in Gas Heating
I've had a number of no heat situations occur immediately after a propane tank getting filled. What happens to the fuel that causes tbis? What can the lp drivers do differently? GW
-1
is this a commercial account? How many tanks? How big? Do the tanks have excess flow valve's installed? How old are the tanks? btw, your post state's "over filled" did this happen at some point since the problem started?0
Gary,
I've noticed in the past you install Baxi boilers, is this happening on them or others? I ask because I have had it happen as well and it seems to be on the Baxi's only. That may just be in my head though. Also, is the driver shutting the valve off for any reason during fill up or after for a test?Tom
Montpelier Vt0
- 128 Chimneys & Flues
