Fiberglass pipe insulation PVC fitting covers
ChrisJ
Member Posts: 17,421
I keep running into this issue and I'm hoping there is a professional looking solution. I have a 3" to 2" reducing elbow and I have insulation on both sides and want to cover it. Of course the 3" side fits good but I have a big gap around the 2" side. How do you deal with this? Just leave it wide open?
Also, why was I supplied with vapor barrier strips similar to the jacket on the insulation? I would assume this is only a concern when insulating something that is cold and may condensate but not a concern on steam piping?
Cut a piece of 3 inch longer than what is needed for the 90. Remove layers from that piece to go around the 2 inch. Install the piece and the 90 , use white mastic on the exposed cut end to seal.
Suppliers usually provide cut tape as a courtesy , sort of like a merchant coupling on pipe sections.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
- 120 Geothermal
