How to clean the deposit from burnham in5 sight glass?
geokes
Member Posts: 13
The picture worth a thousand words.
At this point I'm afraid to touch this for fear of breaking.
Can I buy the whole assembly somewhere?
You can get them from most distributors or here -
http://www.supplyhouse.com/pex/control/search/~SEARCH_STRING=guage glass
That is all brass so it should come apart but you better have a new glass, gauge glass washers and the brass washers on hand before you touch anything.
3PSI gauge0 -
Bob, please elaborate, I'm the owner of the IN5, not a plumber.0
After a second look, I've got it, first I was trying to decipher your signature...0
Make sure there is a stocking distributor close by when you do this in case you need a part - best not to do it on a Sunday afternoon when they are closed.
3PSI gauge0 -
The two things I bought the week after having my Smith G8 boiler installed 3 years ago were a replacement gauge glass and a CO / Gas alarm. I've since picked up an igniter for the Carlin gas gun and a couple of spare radiator vents.
3PSI gauge0
