Incorrect reading on boiler???
jonny88
jonny88 Member Posts: 1,139
House 2750 sqft average insulation typical Long Island construction.38 degrees outside and boiler has house at 70 degrees running on 20k btuh.Target temp 152. Someone once told me baseboard needs 180.Whats wrong with this picture???????
  • BobC
    BobC Member Posts: 5,539
    What happens when it's 5 degrees out?
    Bob
    3PSI gauge
  • jonny88
    target temp will go up
  • jonny88
    yep just proves what you say about oversizing.A/C units are still in the windows about time to take them out.
  • NYplumber
    NYplumber Member Posts: 503
    edited October 2015
    I went past a buddies home today. He purchased the home with a modcon this summer. Its my new toy to tinker with since I like dialing them in. Hes happy because I come visit and lower his bills. Win win for him.
    Very loose home, wood shingles are in bad shape. Bedrooms over an unheated garage with mediocre insulation between the garage and bedroom floors. 32f out here, baseboard heated home. 142f target. Boiler is 110mbh, too large for this home. boiler hits target, jumps down till about 120, turns back on. Works well. If only I can spread the dt across the baseboard. its pegged at 5degrees.
    So, my answer, no it doesnt need 180. but it does need a specific velocity to scrub heat out of the water.
    :NYplumber:
  • gennady
    gennady Member Posts: 840
    Baseboard has different outputs for different AWT, average water temperature, in the baseboard. Lowering entering water temperature you effectively lower AWT, and lowering baseboard output as well, to match heat loss from the space heated.
  • jonny88
    Yep,there is just to many guys who don't believe in low water temps.ODR does give a nice comfortable heat.
    hot_rod Member Posts: 26,580
    It took many years, but heat emitter manufacturers are finally showing output performance at a various supply temperatures. This should help understand lower temperature operation potential.
