Slant Fin Bobcat B-120a problem
ldibs
Member Posts: 1
Hello,
I have recently inherited my home from my grandfather and the home has a Bobcat B-120A boiler installed. With the recent turn of weather it was necessary to turn it on so that the house isn't freezing in the morning. I properly followed all instructions my grandfather had written down on how he started it, which is very simple. I now have a blinking dot on the display panel which indicates the burner is on but not heating. I don't know how to change this issue as it isn't keeping the house warm. Any ideas would be greatly appreciated.
I have no idea what might be wrong buy if you go to the link below you can download in users manual and the install manual.
http://www.supplyhouse.com/Slant-Fin-B-120-NG-Bobcat-B-120-120000-BTU-Condensing-Boiler-Nat-Gas-11367000-p
Hopefully they will have the info you need.
3PSI gauge0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
