Old Cast Iron Furnace
My concern is if they replace the furnace will the old pipes work well with the new furnace? Also they have to replace the burner on the furnace just about every year and can never find the proper size. Any info would be appreciated.
Could you post some pics. I'm guessing this is a boiler, not a furnace if it used rads, and hot water since its replacement won't be Cast Iron. Why do they have to replace the burner every year? That's unheard of.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Can you post some pictures, or have your daughter come up here and post them?
I couldn't find Viking in the site's boiler listings. Is this unit fired by oil or gas?Baltimore, MD, USA
Consulting0 -
It looks like it's an OLD Crane.Steamhead said:Can you post some pictures, or have your daughter come up here and post them?
https://www.flickr.com/photos/bobrenner/142912101100 -
Well, that one must have slipped thru the cracks- couldn't find it in either Beacon or HRH. Maybe the actual model number didn't include the Viking Jr. name.
Looks like a three-pass all-fuel (oil, gas or coal) boiler from the 1930s-1950s. Oil-fired then changed to gas with a Midco E-20. Unless it was well baffled (which we've had much success at), it's probably letting a lot of heat go up the chimney.
System looks like converted gravity, from the pipe sizes. And that PVC tells me the new one is a mod-con....................Baltimore, MD, USA
Consulting0 -
That is a Viking Junior. They are just about indistructable. The baffles are important. I had one in my old 1919 duplexe. I managed to get it up to 85% combustion efficiency in the early 80s.0
I'm amazed Canada allowed you to work on such a boiler without modern approvals?Henry said:That is a Viking Junior. They are just about indistructable. The baffles are important. I had one in my old 1919 duplexe. I managed to get it up to 85% combustion efficiency in the early 80s.
Did it have all of it's factory safety controls? Was anything modified?
Was that boiler originally equipped with baffles from the factory?
Were the baffles approved by the manufacturer?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Did you upgrade the burner without getting written approval from the manufacturer?
Consulting1 -
The boiler had a Rober Gordon spark conversion burner that was previously field aproved. As a licensed contractor, I am allowed to work on gas equipment. Besides having three patents in combustion and heating and being a voting member of B149.1 and B149.2 gas codes. FYI baffles came with the boilers and usualy, the oil tech would remove them. There is one cast iron baffle over the combustion chamber and two curved one in the upper chamber.
At least in Canada, we don't have many people munking about factory certified equipment.0 -
Well, regarding converting my boiler from a drafthood to a barometric which you made a big stink over, just like you Jstar is a licensed contractor and as a bonus he can also pipe a steam boiler properly.Henry said:The boiler had a Rober Gordon spark conversion burner that was previously field aproved. As a licensed contractor, I am allowed to work on gas equipment. Besides having three patents in combustion and heating and being a voting member of B149.1 and B149.2 gas codes. FYI baffles came with the boilers and usualy, the oil tech would remove them. There is one cast iron baffle over the combustion chamber and two curved one in the upper chamber.
What was your vote on this?Henry said:and being a voting member of B149.1 and B149.2 gas codes.
Henry said:Modifications to a certified gas apliance are not permited in Canada. Such a modification would need a field aproval. There is also the problem of liability in case of a problem with the apliance. I am sure that the insurance company would go after the outfit that modified the apliance even if the modification did not cause the problem.
Consulting0
