Old cast iron radiator 90 degree union ftgs
eric2guns
Member Posts: 2
Just checking in to see if anyone would have a source for those 1-1/4" 90 degree elbow
unions. Installing a few old sectional types and they include half of that union. Next
option is to cut and chisel. Thanks much.
Unless you can find the same manufacturer of the fittings (if they are old don't even bother looking) they will have to be replaced. Cut the inside almost to the threads in a couple of places and fold them in and remove.0
Thanks Rob, figured that's where it would go.0
I'd give the spud wrench a shot, first. The worst that could happen, is, you snap the nubs off. Then it's back to Rob's plan.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 891 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
