missing plastic ball in the Triangle Tube Condensate Drain Assembly
Vad
Member Posts: 55
I found today that the plastic ball is missing in the Triangle Tube Prestige Solo 110 Condensate Drain Assembly. The boiler is working like this for 5 years.
The manual is pretty clear says not to install the assembly if the ball is missing.
What damage to should I expect?
Thank you,
regards,
Vad
Thank you,
regards,
Vad
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
