wall hung boiler
ddenny
ddenny Member Posts: 75
hello
I heard about a noncondensing wall hug gas fired boiler with a copper heat exchanger that you can direct vent without a chimney using PVC. do you know of such a boiler?
  • Aaron_in_Maine
    Aaron_in_Maine Member Posts: 315
    I believe the Utica Cub boiler is what your looking for.
    kcopp
  • kcopp
    kcopp Member Posts: 4,700
    still prob need a liner.
  • todd_ecr
    todd_ecr Member Posts: 92
    The CuB boiler is Cat 1 or Cat III vent. You can not vent it with PVC. You can use PVC for the intake. The exhaust vent can go into a properly lined masonry chimney, or a B-vent style chimney(Cat I) or sidewall with AL29-4C stainless steel(Cat III).
    The Cat I vent connector(pipe running from the unit to the chimney) should be B-vent.
