Identifying a steam system component
This one has us baffled! It is a component in a low pressure steam system in Philadelphia, about 16" diameter, and is leaking...not sure what it is or what is does (or did) and wondering if you may be able to identify?
The first picture is a side view and the second is a bottom view (looks like there used to be an actuator?)
    Steamhead Member Posts: 18,500
    Looks like an expansion joint, which lets the pipe move as it expands so as not to put any strain on the joints.
    Consulting
  • JStar
    JStar Member Posts: 2,752
    I would sacrifice a small chicken to the steam gods and take my chances with opening that hatch.
    RobG
  • gerry gill
    gerry gill Member Posts: 3,084
    Gotta be some sort of name on it, no?
    gwgillplumbingandheating.com
  • Paul48
    Paul48 Member Posts: 4,469
    That does appear to be a motor mount.
  • JUGHNE
    JUGHNE Member Posts: 11,549
    edited August 2015
    How about a bolted flange with a plug in it, which would turn the whole fitting into a tee. The flats could be for a zone control for the tap of the tee??? (Go ahead open it, small chickens are cheap ;) )
  • Paul48
    Off the bottom of a main?
  • JStar
    edited August 2015
    My first impression was steam-turbine or zone valve.
  • Paul48
    WAG........... Designed for a zone valve. Wound up as just a section of pipe, never used as intended.
