Caleffi LLH
jonny88
Member Posts: 1,139
2 week wait for a 11/2 Caleffi LLH.How is this possible.NY by the way.Spirotherm is available but not magnetic think I can wrap a magnet around it.?Really like Caleffi products wish there was more support here or does anyone know a good supply house that carries their products.Rathe is a 2 week wait.
Out here we have one or two places that keep stock on some of the little stuff, but every time I have ordered anything large, or anything with -mag in its name, it ships out of Milwaukee.0
Fw Webb should be able to provide it faster Jonny . I can probably have it to you faster than 2 weeks . Maybe I should jump into the rep field as a new entity . Better prices and more sales would not be bad for anyone .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Are you looking for an 1-1/2 Sep 4?
We do our best to forecast and keep product in the warehouse. Sometimes our weld shops fall behind. Most of the welded products are built in the US.
Let me know the model # of the one you need.Bob "hot rod" Rohr
Living the hydronic dream0 -
That is what I need in 11/2 sweat.Will confirm in the morning.Thank you kindly.0
hey hot rod is that sep the same dimensions as the 548 series was looking to add a magintic sep to my system and the easiest way would be to just replace the 1 1/4 548 that i have in place now thanks peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Clammy, I'll check with engineering for the dimension sheet.Bob "hot rod" Rohr
Clammy, the 1-1/4 sep 4 has a 9-3/4 face to face dimension, the 548 has a 9-3/8" So unless you have some wiggle room, it may not be a direct swap.clammy said:hey hot rod is that sep the same dimensions as the 548 series was looking to add a magintic sep to my system and the easiest way would be to just replace the 1 1/4 548 that i have in place now thanks peace and good luck clammy
I'm trying to find the face to face dimension on the barrel nipples without the tailpiece.
Update; Kevin took two off the shelf and measured both units up in Miulkwaukee. With the nuts and tail pieces removed they both measure 7-1/4 face to face. The center to center, top to bottom matches also.Bob "hot rod" Rohr
Jonny, they are on the shelves in Milwaukee. You supplier should be able to get one within a few days. We didn't see one on any shelves near youBob "hot rod" Rohr
Fantastic thank you so much it is really appreciated0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
