Latest Steam Boiler Install
JStar
JStar Member Posts: 2,752
Replaced an old WM oil-fired boiler with a new Peerless 64-10 in Montclair, NJ. The old boiler was piped correctly, but only had a 3" header, trying to move 515MBTUH+. We installed a 5" drop header with two 3" boiler risers. Added a Vaporstat and 2-stage GCV. The system is a mix of one-pipe radiators throughout the house, and two-pipe indirect heaters in the basement. The wet returns were 30" high off the floor, so we kept our Gifford Loop above that level to keep them wet. The old boiler sections looked like they were never cleaned, and the soot had turned into concrete. Of course, the service tags were always filled out.
  • JStar
    And the new boiler.
    RobGChrisJ
    Steamhead Member Posts: 18,211
    What was the old one- 76 or 78 series maybe?
    Consulting
  • SWEI
    SWEI Member Posts: 7,348
    Nice work (as usual)!
    RobG
  • JStar
    edited July 2015
    480. Which WM made from 2002-present. That's a lot newer than I thought. The inside looked like it had been neglected for decades.
    Those 80-series boilers run nicely with gas burners. But like anything, if they're neglected enough, they won't last. And the 4-80 requires a minimum 4-inch header- only the 3-80 can get away with a 3-incher.
    Nice work.
    Consulting
  • JStar
    We discussed the option of converting the existing boiler to gas, but the homeowner wanted to replace everything. Good thing, I suppose, from the way it looked on the inside. I don't think it would be too much longer before the sections would start to deteriorate and leak.
    ChrisJ
  • RobG
    RobG Member Posts: 1,844
    How many times did you trip over that wet return running across that entryway?
  • JStar
    Luckly, that was not our entrance. Instead the basement doors were about 50 ft away, around two corners, and through a doorway where an indirect heater had previously fallen off its hangers on the ceiling.
  • RobG
    edited July 2015
    Sounds like fun! :'(
    At least it wasn't a hoarders house by the looks of it.
  • JStar
    Of course, the bigger the boiler, the further the boiler room is from the basement entrance, and the more narrow the stairway is.
    kcopp
  • RobG
    Do you have a company you use to replace rickety stairs or do you leave that to the client? I've got a carpenter that I will refer the HO to but it is between them and him. Some of those old stairs I will refuse to bring a boiler up nor down.
  • JStar
    We don't at the moment. Sometimes we'll offer a price to sure up the stairs ourselves since we do some handyman style work. I had an instance at another company where my helper convinced me that he could handle the top of the hand truck. We got to the first landing on the stairs, and the boiler dropped straight through to the floor. I don't even remember how I jumped out of the way.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Another great looking job!
    Looking at the first new boiler picture, the steam main on the left appears to be counterflow for the first 3-4' before the 90. How far could that go before turning into parallel flow without causing a problem?
    Not being critical, just that there are a couple of situations I know of that might get re-piped in the future and there is about that horizontal distance before reaching the high point of the steam mains. They are parallel flow for the rest of the main. Reusing that existing portion of main would save a lot of grief and probably pain.
    Thanks.
  • JStar
    My rule is that the pitch can go either way as long as it's before the first radiator run-out.
  • JUGHNE
    Understood; no radiator condensate should flow back into the header, only steam main drip and that should be very little especially if the main is insulated.
    So consider that as an extension of the vertical main riser off of the header?? Just don't leave it flat to pool water.
    See why you should stay in the field to direct/advise newbies like me? I would have pulled both arms out of the sockets and probably cut up floor joists trying to "correct" that slope.
    Thanks again.
  • Dave Stroman
    Dave Stroman Member Posts: 765
    Could you tell be about the 2 stage gas valve. My local Peerless rep is telling me it should not be done on this boiler. Does it have 2 gas trains?
  • Paul48
    Paul48 Member Posts: 4,469
    JStar.........Why is the Hartford loop so high?
    Consulting
  • Paul48
    Sorry....I missed that.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Love that header!!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • ChrisJ
    ChrisJ Member Posts: 17,073
    Are those cast iron fittings as usual Joe?
    Beautiful work.
  • JStar
    Beautiful work.
    ChrisJ
  • kcopp
    kcopp Member Posts: 4,630
    No Pro press? just kidding!!! :o
    JStar
  • Abracadabra
    Abracadabra Member Posts: 1,949
    heh... propress is only for vertical headers ;)
    JStar
  • JStar
    I would only use ProPress fittings on my old boss's steam boiler.
    RobG
