do i need to lower the pressure of the boiler?
sunwave
Member Posts: 30
I've heard the ideal pressure of the hydronic heating system is 12-15psi, but YMMV.
My building height is 25fts max, my boiler stays at 20psi even after i turned the nut of Watts pressure reducer counter-clock .
Do i need to do something else to lower the pressure or it's okay to have 20psi. Any suggestions?
For a typical single or two story residence, yes.sunwave said:I've heard the ideal pressure of the hydronic heating system is 12-15psi
The height that really matters is measured between the lowest circulator and the highest pipe, radiator, or other component. If that number is 25 feet, you would look for a minimum static pressure of about 16 PSI. 20 PSI will work just fine.1 -
I think I will add a gauge next to the pressure reducer to gain more accurate reading.0
When you lower system pressure, you have to release pressure to bring it down. Open a bleeder on the top floor, then check the pressure again.
http://media.wattswater.com/1910265.pdf0 -
Thank you for the info.!Paul48 said:When you lower system pressure, you have to release pressure to bring it down. Open a bleeder on the top floor, then check the pressure again.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
