Noisy Wall A/C
I have a Panasonic 13,500 BTU a/c that is mounted thru the wall. Yesterday, I turned it on for the first time and it sounded like a motorboat but is sending out cool air. It is 13 years old and have never had a problem. What could be the cause? Thank you
  • BobC
    BobC Member Posts: 5,549
    get some help and pull the unit out of it's sleeve and make sure there isn't anything hitting the fan. Also see if there is a broken motor mount. If it's deeper than that it might be time to consider a new one.
    I have the same unit and it's probably a couple of years older, still runs fine.
    Bob
    3PSI gauge
  • Carmine
    Carmine Member Posts: 10
    Thanks for your help
