Honeywell Vision Pro 8000
Nick83
Member Posts: 1
I just installed this thermostat when I have the temp set at 70 degrees from 5pm until in the morning is when it finally catches up and turns off.. Does anybody think the problem could be I connected the heat pump wire when my AC doesn't have a heat pump...
Did you read the installation manual (the white pages) that comes with each HW t-stat? It asks you about your system, step by step for wiring and programming. If the questions are too challenging you might need professional help for the install.0
What's "the heat pump wire"?0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
