Alpine
happydave
Member Posts: 79
Latest adventure, Burnham ALP 285 tied into heating system and indirect not firing. The boiler goes thru pre-purge, goes to ignition cycle and directly to postpurge. It will do this all day long with out firing but doesn't give a error/fault code, bad control module? Thanks
It's the high limit switch
No fault code comes up, always shows string fault0
- 125 Chimneys & Flues
