Replace indoor oil tank? pictures attached
mr3ttech
Member Posts: 4
Long time lurker 1st time poster....
Considering replacing a 40+ indoor oil tank preventatively with an
outdoor Roth dw tank. Roth height is an issue for current indoor location.
Currently no leaks - wanted opinions on condition of under tank pictures.
see links.
Thanks,
mr3ttech
see links.
Thanks,
mr3ttech
Roth does make a tank that is 54 inches high. Your tank does look questionable but, it might just be paint coming off.
Kinda hard to tell with the pictures and not being there.0 -
40 years? Definitely time for a replacement.0
Advice 1 get a licensed company to do it.Dont tackle it by yourself it can turn into a big mess.Company will come cut tank suck out oil squegee tank and clean it then cut it up and remove if necessary.You also get paperwork.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
