How do you insulate PEX??
EBEBRATT-Ed
Member Posts: 19,330
What do you use on pex?
Fiberglass doesn't bend.
Armaflex dries out when used on heat.
If using Armaflex on chilled water the ID of the armaflex doesn't match the pex od. Air can get between the pex and insulation and cause condensation.
We had a horror story in a data center raised floor because of that.
What's the answer
What's the answer
I'm curious as well… I've seen lots of PEX installs, no insulation. My understanding is that its a poor conductor as compared to copper piping.0
We use Armaflex or similar polyolefin foams on heating pipes. The refrigeration type (continuous roll with no split) holds together better, but requires a bit of planning. Someone here pointed out that hot glue holds joints together really well.
We like Aquatherm for chilled water, at least at larger diameters. PEX pigtails to coils and such become a tiny part of the overall system. They sell (and have approvals for) Reflectix wrapping, which doesn't seem to produce (or care much about) condensate -- though I'm a lot less enthusiastic about its performance with hot water.0 -
Cut it out and use copper...Joking
most pex-a's are rated for a Plenum up to 3/4" in US and 1" in Canada without requiring insulation. Uninsulated they will usually require a min of 18 oc spacing between tubing.0
Mark,
That's a good trick.
I usually duct tape the end especially when sliding it on refrigeration piping to keep the "baby powder" and rubber flakes out but the copper cap is a better idea + no gummy tape residue to get off before brazing or soldering0 -
jonny88 FYI the sox are coming to the Bronx…i predict a sweep, by the sox…Your starting picture seemed a wee bit off on opening day…Oh also on our home opener the Super Bowl Pats are expected to be there…Gee maybe the Jets will show up for your opener, can’t imagine why…LOL……Seriously thou if your ever up in Boston your welcome to Fenway, as my guest…. Nothing like a Fri. nite game in the summer against the Yanks…Its a side show0
j a just cause I live here dont mean I root for Wankees sorry typo Yankees.Would love to take you up on the offer had many good times up there
Hay feel free to contact me japlumbing38@comcast.net. 6176886802. Truth be told I always enjoy watching the Yanks....They are to baseball as steam heat is to our industry....0
No pex is not going to show. I don't like anything plastic or propress or megapress or Aquatherm. Screw it, solder it, weld it.
But this is a job for pex. Hot water feeding fan coils inside a hollow wall, won't freeze and won't show. Kills me to admit it's a good application for pex. Have to be realistic.
As far as Red Sox -Yankees, I'm a diehard Yankee fan from Western, MA so I have been taking S--t about it for years.
I must admit this year we don't have a chance!!0 -
Yes. Must admit I have used it as well...Somehow the Yanks end up pulling it out....lots of storied history with them....0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
