What is the EDR of this Radiator
Jerrkyd
Member Posts: 4
Hello, I am trying to calculate the EDR of all of my radiators. I am a homeowner and dont have access to "The book" of radiator EDRs. The radiator pictures is identical to all of my other radiators so all I need to know is what the EDR is for one section. The radiator has the name, "Richmond Radiator Co" cast into the side. It stands 38 inches tall abd, each section has 3 fins. The two outer fins are 2.5 inches and the middle fin is about 3 inches. I
5 EDR per section0
Snoop around off the wall in the Library and Heating museum. There is a lot of good reading on sizing rads with charts. Start here: https://heatinghelp.com/heating-museum/category/radiators
The second entry should get you started. Do a search for "edr" on The Wall and you'll find additional pdfs referenced.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Thanks Fred.0
I agree with Fred, that radiator is 5 sq ft per section.
3PSI gauge0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
- 49 Job Opportunities
