Can someone please tell me where I can buy this steam vent or something similar?
John12345
Member Posts: 3
Hi All,
I have an in-wall steam radiator with a bad vent that need to be replaced. The space is very small so I cannot replace it with a regular vent that Home Depot carries.
Attached is the picture of the vent. Can someone please tell me where I can buy one of this or some thing similar to replace my current vent?
Thank you,
John
Thank you,
John
Are you sure it is a steam system, a lot of air vents for hot water radiators look like that. What is it doing/problem?0
If it's a steam convector then this is what you need:
http://www.supplyhouse.com/Hoffman-401475-508-1-8-Straight-Steam-Convector-Air-Valve-3521000-p0 -
This vent, which may be the only one you can use because of space limitations, lets the air out slowly as steam rises. That makes it more important to make sure your main venting is very generous, or your fuel consumption will soar, a and your comfort level will be low. Make sure your pressure is below 1.5 psi for vent longevity.--NBC0
Thank you all for your responses.
Yes, it is a steam system. When the heat is on, it makes loud of noises and lets steam out non stop. Also water dripping from it too.JUGHNE said:Are you sure it is a steam system, a lot of air vents for hot water radiators look like that. What is it doing/problem?
Abracadabra said:If it's a steam convector then this is what you need:
What is the diff. between a steam convector and a regular steam vent?nicholas bonham-carter said:This vent, ....--NBC
Thank you again for your help.
John0
