Union Sweat/NPT vs. Direct Sweat/NPT
hydronical
Member Posts: 24
Why do some components have union sweat and union NPT connections, while other similar components have direct sweat and direct NPT connections? For example the Caleffi NA5453 DirtMag has union sweat and union NPT connections, while the Caleffi 5463 DirtMag has direct sweat and direct NPT connections...
If the device was built with unions as part of its design, they just install the tailpieces for whatever system (sweat, NPT, or press) needed. I suspect those union threads are standard "G" style, which means you actually have even more options for piping if you need them.
The sweat version of the 5463 comes from Italy with BSP threads in the body. They install BSP x sweat adapters in those over here (using Loctite.)0 -
@hot rod - any additional thoughts on this?0
In some products we use the Euro bodies which have BSP threads. So we just add tailpieces to adapt to sweat, NPT or press
If we start with a new forging or casting it can be machined to sweat or NPT
NPT requires a deeper socket to machine a tapered thread. BSP can be a shallow thread, which seals with a gasket or hempBob "hot rod" Rohr
Living the hydronic dream0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
