Space heat and DHW combo units
DenverBoilerGuy
Member Posts: 5
Have a cliient who really needs to go with due to space limits. So far I've examined a Navien combo unit and one from HTP. Thoughts?
I also wish I could change my user name; I was a lot more full of piss and vinegar several years ago when I set up the account0
What is the DHW demand? I use the Triangle tube Challenger and the Bosch Greenstar. I also have used the Cosmogas, Smith, embassy, peerlesss g160C....great HW output. It is a bit finicky at times.0
3 adults with differing schedules. The local Navien rep told me they put out about 4 gpm at 1250
HTP Versa Hydro. What's the heat loss?0
If space is a concern you can choose from the HTP EFT C they have a wall mount and a floor mount combi. The floor mount is sweet and does not take up much space. Has a small buffer tank built in with a coil inside for DHW.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
I found the Navien NCB-240 to be the best bang for you buck. The Challenger and HTP EFT are limited being as they only go up to 125mbh and 140 mbh, respectively0
I calculated 110 MBH for heat using typical Denver retrofit parameters, his existing boiler is 120. I installed a HTP combo in a high dollar condo in Vail 4 years ago and it works like a champ, so I am mostly wondering what folks here think of the Navien combo.0
What are typical Denver retrofit parameters? How many square feet is the house?DenverBoilerGuy said:I calculated 110 MBH for heat using typical Denver retrofit parameters
2
