2 Pipe Vapor System by Moat
Tabauer
Member Posts: 3
I have a Moat vapor system which, thanks to Gerry Gill, is operating far more efficiently than it did when I bought the house. The house is a 2 story brick built in 1925 with R-46 in the attic with a radiant foil barrier. The boiler last time I checked was working at about half a pound of pressure. The problem is that my drafty 2nd floor gets much hotter than my draftier 1st floor. The 2nd floor has one room with a television, stereo, cable box etc which all give off a ton of heat so the room gets unpleasantly hot.
The original Moat valves are in place in all the rooms and although very hard to turn or sometimes won't turn at all appear to be o.k. I do not want to replace the valves since (if I understand correctly) vapor systems require special valves or I'd have to modify the new valves with a disc with a pin whole in it and I like the look of the original valves. So, I have removed and cleaned one of the valves (in the room that is way too hot) and do not see any apparent damage or failure. I intend to re-install the valve and move the calibration stops so that I can close the valve off completely (I hope).
Should I apply some kind of heat resistant lubrication to the valve parts? I was thinking of the grease used to lube the cam when re building an engine. (not that I've ever done that!)
Also I am concerned about the effect closing off more than one or two radiators would have the rest of the system. Will I end up building too much pressure or cause short cycle burner firing?
Any advice on these valves or a Moat Vapor System will be appreciated.
Thank You.
Tom Bauer, Detroit Mi
Thank You.
Don't use any lubricants on those valves. The last thing you want to do is introduce oils/grease into the system. It will eventually work its way back to the boiler and require you to skim it off of the surface of the boiler water.5
Would it be difficult to work on making the first floor less drafty and more similar to the 2nd floor draftiness?5
Fred, Thanks, I should have thought of that myself so I'm glad you were here to keep me out of trouble! I did find that there is a rubber? washer much like a faucet washer at the end of these valves which on some was gone completely and on others there were fragments of this washer broken away. Tomorrow I plan to look around for a suitable replacement. Meanwhile, I can now turn some of the valves and reduce the heat coming into some of the rooms that are getting too hot. I have to wonder though if dialing back radiators in some rooms isn't forcing more steam to others or creating too much steam pressure? System doesn't seem to short cycle.
Abracadabra: It would not be too difficult to reduce draft on the lower floor...... just too expensive. I am replacing some windows this year and hope to do a few each year. Most of my first floor windows are stained or leaded glass and would require a restoration and a couple of them walked away when the house was vacant. I am chipping away at the windows and doors a little at a time. Chipping, Chipping, Chipping.... 8 years of chipping away....
Thanks to both of you for the replies.0 -
The radioators in the other rooms won't take on any more steam than they can condense. I think you can try to turn the hot rooms down some and as long as you don't reach a point where the boiler starts to short cycle, you should be OK.5
Thanks again, Fred. My next "mission" is going to be hunkering down on the drafty window repair & replacement.0
What about radiator covers or painting the radiator an appropriate color to reduce output?5
I have a Mouat system too and I don't think what you are describing is peculiar to that system. I think relative temps 1st to 2nd floors will vary some from warm days outside to very cold ones with any steam system. We aren't stirring it all up and moving it all around like forced air does. The variance to me is not that much.
However if I had one room(s) with other sources of heat that was really too hot I would use the valves to slow down that rad(s). I do this in some places. All my valves are still original and all still work. I have not had to do any maintenance on them. Some need a gentle back and forth motion to move them but I don't worry about breaking anything. I really don't change them much.1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control5
