I Don't Understand What Happened!
Rich Davis_2
Member Posts: 103
Hi, It's been awhile since I've used this site. I look after a steam boiler at my church. We were having a problem with over heating in a room. There is a loop off the main pipe that is operated with a steam valve that is operated by a Honeywell M9164D1009 Modutrol actuator. What was happening you would turn up the thermostat ant the valve would close and turn down the thermostat the valve would open. So I removed the actuator and turn the crank around. Put it back together now the actuator doesn't work at all. Got 24v on the transformer wires and the thermostat has connunity when it should and no conn unity when it should. Everything is back like it was and it just don't operate. Im at a loss, any suggestions? Thanks Rich Davis
OK0
- 84.4K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3.1K Oil Heating
- 57 Pipe Deterioration
- 801 Plumbing
- 5.5K Radiant Heating
- 372 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 81 Job Opportunities
- 22 Recall Announcements
