Old steam part
stanzygo
Member Posts: 10
Improved air exhauster perhaps?0
Why did they take it out?Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
KC nailed it. It's an air vent from an O-E System. It was mounted on the dry return and used an expanding post to close the vent, and the ball was a check valve that kept air from getting back in. This let the system go into vacuum as the coal pile burned down.
The O-E, along with the Kriebel and the Richardson systems, was one of the few systems that would permit steam to enter the dry return.
I believe O-E (like Milvaco and Sterling) was located in Milwaukee. Are you located in that area?All Steamed Up, Inc.
Consulting0 -
Nope located in Massachusetts. There was two of these located on returns no longer hooked up. Boss had me take one and couldn't find out what it was..... So I tried here! Thanks very much for the info0
Is the steam system you removed this from still operating?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
Here in the inventors own wordsgwgillplumbingandheating.com
Wow awesome where do you find stuff like that!!!!0
You can't hang around here and not become smarter.
Who'd a thunk?0
