Drop header with 90 degree ELL to the system mains
mercedes
Member Posts: 67
Hello, Installing the Near Boiler Piping on Burnham IN5 and I am using the drop header and both riser from the boiler. Having 24" above the boiler. The header on the drop, if I go straight out to connect the two system main I would hit the wall of the house. Could I install 90 ELL after the last riser Tee with a 6" nipple then the elbow and pipe as normal to the system main and return. See attach picture
thank you
thank you
+1 on that...did it on mine (see link in signature). Also helps get a little extra distance between mains and boiler to help settle things down and separate steam from water which is the ultimate goal.0
Gentlemen Thank you. will make that 90 degree turn. Dry steam ahead
great drop header !!! I have the same IN 5 and plan on doing wi the same thing this summer . With the IN 5 is 3 inch good ? 4 inch would be over kill?0
3" is fine. 4" is probably a bit over kill.0
