Can I use a recirculation pump and line for DHW with Navien?
Xmytruck
Member Posts: 85
Hello ,
Just wondering if I can use re-circulation pump for DHW to get instant how water on Navien like a CH240, it has a re-circulation built in so could I cause damage if I installed one?
Thank You
Xmytruck
Thank You
Xmytruck
Yep you can but have to follow some rules with these tankless where are you calling from.
Thinking about pulling right before it heads to the second floor.0
When I do recirc on a tankless taco just renamed there circulation pump it's called genie pump. That will get you the best bang for your dollar. Also what I do is add a air eliminater and a potable expansion tank. I would also make the return 1 inch.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 982 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
