Bad Gorton #1 Steam Vent?
colonelcasey
Member Posts: 17
I got a Gorton #1 steam vent off Amazon to replace my leaking Hoffman 45 vent for my main in the basement. While the Gorton #1 closes and doesn't blow out steam, I noticed a leak developing at the very bottom of the circular chamber where the cover is sealed to the main body. I thought I just had a defective vent so I replaced it with a new one. However, I noticed my replacement vent is still leaking, possibly from the same area.
I've heard good things about Gorton vents before. Is it that I've just got two defective steam vents in a row? Or is there something else going on in my system that's causing it to leak from the vent body cover? Pictures are attached of where I saw the leak develop on the first vent I got.
Both were third-party sellers on Amazon. I'm going to keep an eye on the replacement vent I'm using but if it keeps leaking, is there a more reputable site to get a Gorton #1 vent?0
You can also get them from Supplyhouse.com They ship fast and are good about any returns.0
The bottom of that vent loks like someone dinged it or got a channel-lock on the body inadvertantly.0
I see the same thing, clearly a crease in the housing just above the hex.Abracadabra said:The bottom of that vent loks like someone dinged it or got a channel-lock on the body inadvertantly.
I buy all of my Gortons from Supplyhouse.com.
If I have any problems I just contact Ken over at Gorton. They are one of the best companies I've ever dealt with.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
