Boiler problem
Dane
Member Posts: 1
I recently moved the lines to a new tank in the basement and changed the pump and put a new nozzle on the boiler. now when the pump is off it keeps spraying into the boiler. any suggestions would be greatly appreciated. Thank you
You say "lines", is this a 2 pipe system? Why was the pump replaced? Sounds like a bad check in the pump? Need more info, and pics always help0
I assume your talking about oil lines. Oil fired boiler.0
- 167 Indoor-Air Quality
