New Furnace & Broken Radiators
jlr329
Member Posts: 2
in Oil Heating
I have a property that needed a new oil burning furnace in the basement. When the installer let pressure into the system, he said 4 of the 7 radiators have cracks and/or are leaking. This is all new to me and I'm looking on here to find out what the right questions to ask. He suggested replacing the radiators with baseboard heating and replacing all of the existing black pipe with $cop$per$. I wasn't prepared to replace the furnace, and now we're about to rack up another few thousand in replacing broken radiators. What is the next step? I found a person on-line who is selling working radiators, but I'll have to measure them to ensure the proper fit. How do I measure them? What should I look for? I need all the help I can get because this is more than I bargained for this winter.
Is this a steam or hot water system?0
Hot water.0
Had a job with leaking radiator. Turned out that there was not effective air compression tank and someone had put a plug in the pressure relief valve. After everything corrected the leak went away. Was the system ever frozen or subject to really high pressure (over 30 PSI)?
Rad valves can leak and are an easy fix or replace.0
- 120 Geothermal
- 169 Indoor-Air Quality
