Check your filters
GW
Member Posts: 4,693
Look what my tech just brought me. Time for a new limit switch.
What breed is that?0
A Western Mass Fur Ball--I'm not sure what it is.0
Only time I see that is AFTER the ducts are cleaned.0
I can only imagine what the upstairs looks like0
This is just a 45000 btu 80% too! not sucking tons of air. the landlord forgot to tell the tenant they need to change filters.0
Wow. How did they get any heat at all? Hopefully limit is available. If there was no filter, I'm sure there would be much bigger problems. Nice0
Limit is coming today, landlord not happy, tenant not happy, no one is happy.0
On the last one I had, my old school goto guy said to give it a tap to reset it for temporary. It worked. Still waiting for nordyne limit 10 days later. Removed filter for time being to get full flow. I don't think you can do that though.. It will suck the remaining hair down. Gross.0
yes, i'd rather not run w/o a filter..can you put a new filter in, or at least de-gunk your dirty filter and beat it against the sidewalk to clear it off a bit?0
Running without filter to keep limit from tripping while waiting 2 weeks for new limit(!!!) Sheet metal installed by hacker who omitted filter receiver. Will get something in there when I go back.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
