Hot water heater exhaust question.
misterheat
Member Posts: 158
Hi all, my gas fired hot water heater and my gas fired IN 5 boiler both exhaust into the same chimney.We use a lot of hot water in the house so it runs alot . I'm A home owner not pro, so im still learning . With that said. Question; Does the exhaust from the water heater help keep the chimney temp warmed up a bit in between cycles of the boiler ? Because i believe a warmed chimney is advantageous to better operation of boiler ? thanks
thanks !0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 393 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 46 Industry Classes
- 49 Job Opportunities
