What fitting to use coming off boiler?
Oldslowandugly
Member Posts: 37
I have a Burnham IN5 boiler with two 2" outlets, only one is being used. I want to use both outlets and raise up 3', offset a few inches, then drop 2' to a 3" header. I was going to use unions right at the boiler to extend my pipes up, and then again at the header, for ease of assembly. But I have seen unions, couplings, and companion flanges used right at the boiler to connect to the piping. What is best to use? And is a few inches offset enough? I want to avoid stressing the boiler sections at all costs!
Any of those will work. I have flange joints on mine but it seems most are using unions now. Couplings can be used to extend the risers but are not convenient if/when you need to take things apart at some later time.
Use 90 degree elbows at the top of your boiler risers and at the point where you turn down to go into your drop header. Those are your swing joints that relieve stress on your boiler block.0 -
Thank's Fred. That was my intent, ease of assembly/dis-assembly. I only have room for 3" or 4" nipples between the elbows, is that enough? And how do swing joints work? Do they unscrew under stress, or just "give"?0
Good advise .
Do manufacturers suggest drop Headers?
I dont believe so ,but why0 -
If you have 3" or 4" after screwing the elbows on that should be fine. Those elbows just flex to provide relieve stress on the boiler sections. In reality they probably do "Swing" back and forth on the threads but it is so minuscule you can't see movement. You want them good and tight when you build your header so they don't leak. Don't try to allowi for swing. That will take care of itself.0
That is my goal- a super dry steam boiler. I will re-do all the near boiler piping as space permits. Many thanks to all who responded!0
@wmtandson, some manufacturers give good, better and best install suggestions and use the drop header as a "best" practice. It was REQUIRED on my Slantfin Intrepid install, but they seem to really put a lot into their install manual and technical advice. I had a few potential installers want to by-pass using it, but they were shown the door. Eventually, I did it myself with help. ColleenTwo-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
My Burnham installation manual has the same exact drawing Dan used in his Lost Art book. It shows 2 risers, with offsets, a header, and the mains taken off after the last riser and before the equalizer. His captions were "manufacturers specs" and "how it went in"- mine is the "how it went in". DOH! Thus, out come the wrenches.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
